godsmile
#1 Posted : Wednesday, November 3, 2010 11:22:22 AM(UTC)
godsmile
Hello,
I replaced the spark module and the cooktop still wants to ignite. I am now replacing the gas valve switches. Can anyone please instruct me on how to do this?
Thank you,
Jaquie
#2 Posted : Wednesday, November 3, 2010 3:10:24 PM(UTC)
Jaquie,
Remove the glass top the same way as you did it to replace the spark module to access the switches. Pull out the wires from the old switch and remove the switch from the gas valve stem. Push in the new switch in exactly the same position on the gas valve stem and push in the wires into the new switch terminals.
- The gas valve (ignition) switch Part number: AP3191247
godsmile
#3 Posted : Thursday, November 4, 2010 6:29:26 AM(UTC)
godsmile
YOU ARE THE MAN !!! Blessings to you! May the joy of the Lord over flow you this Thanksgiving!
Jaquie
#4 Posted : Friday, November 5, 2010 1:20:22 PM(UTC)
Jaquie,
Thank you for your good words. I'm glad to be of service.
