I know I keep posting to my thread, but I figured I'd keep a running log of the events as they occur. As of this morning the glass of water I'd put into the freezer is frozen solid, fridge is cold etc. seems the compressor is working as normal with the starter relay as it kicks on and off as I believe it should. Will update again.
Congratulations!!!
Sounds like you are up and running.
And thanks for getting back to us. Now when others search for a similar problem they will see what actually worked instead of just suggestions about what could be the cause. |
THIS FORUM IS DEAD!!!!!!! |
