My washer works on the normal cycle only. When set to the delicate cycle, the water fills up and when it should start to adgitate, it just buzzes, then if you wait a few minutes, it will run the water out. It has not washed the clothes through a normal wash, rinse, and spin cycle. It does this in the perma press cycle also. Would this washer need a timer part?
Thanks!
Normally, I would remove the timer cover and check the contacts, if badly burnt, that's your problem. If not, you may have a bad motor or a bad pin on the connector. If you have a meter, check for voltage to the motor pins per the schematic and push in on all the connector pins, they may have worked loose.
