chadgrooms
#1 Posted : Tuesday, November 2, 2010 4:34:56 PM(UTC)
chadgrooms
The stove top is working,but inside of the stove is not working ( heating eliments is not heating, both broil and bake.) The inside lights are also working.
#2 Posted : Wednesday, November 3, 2010 2:51:45 AM(UTC)
Replacement parts for FRIGIDAIRE GLEF378AQF Frigidaire/electric Range | AppliancePartsPros.com
Here is a good link with info on stove repair.
http://www.applianceaid.com/elecrange.html
If the oven says it is ready and there is no heat it could be an oven sensor problem. See Item 7, 8 and 21 in the above link.
I do not know if this unit looks for an open sensor so I would check it.
Check for a burned off wire of a bad connection from the control board to the elements.
If both the above are OK then odds are that the control board is toast.
Always remove power to the unit when working on it. 240 volts is lethal!!!
propane stove not working, no gas (Oven Repair (including Ranges and Cooktops))
by craigerpo 4/25/2015 4:16:05 PM(UTC)
Maytag CRE8700DDE stove not working at all! (Oven Repair (including Ranges and Cooktops))
by psamek 10/30/2012 8:35:31 AM(UTC)
stove not working right (Oven Repair (including Ranges and Cooktops))
by BSA_T524 8/9/2008 9:50:35 PM(UTC)
