tejardine
#1 Posted : Monday, November 1, 2010 3:40:28 PM(UTC)
tejardine
Whirlpool Imperial series gas dryer, Everything works not heat Ohmed Thermal Fuse T Stat Internial Bias Flame Sensor nothing open and Ignitor heats up, but not ohms on the gas valve coils according to specs I should have 1220 +/- 50 on the 2 terminal and 1365 left to middle and 560 left to right +/- 25 on the 2 terminal. If this is correct my coils are bad is this correct?
Thank you much for your time
#2 Posted : Monday, November 1, 2010 7:23:35 PM(UTC)
Very likely the problem is a bad coils.
- The coil kit Part number: AP3094251
Double checking Bosch parts needed (Dishwasher Repair)
by acronce 9/15/2008 6:20:49 AM(UTC)
