skolnabber
#1 Posted : Friday, August 8, 2008 10:49:55 AM(UTC)
skolnabber
There appears to be a gap at the front of the drum where clothes periodically become stuck and as a result, small brown burn streaks are created. I've read elsewhere that the felt seal needs to be replaced. Is this correct? And, if so, is this relatively straight forward for someone who's good at taking things apart / putting things together?
thanks very much for any help!
abadfish66
#2 Posted : Friday, August 8, 2008 11:25:25 AM(UTC)
abadfish66
You are correct, the felt needs to be replaced, it's pretty straight forward, remove the front of the dryer, remove old felt, get rid of as much of the left over felt as possible. and glue the new one in place.
abadfish66
#3 Posted : Friday, August 8, 2008 11:26:57 AM(UTC)
abadfish66
skolnabber
#4 Posted : Friday, August 8, 2008 2:00:21 PM(UTC)
skolnabber
Appreciate the info. One last question... You mention above that the felt should be glued in place. Is there a special type of glue you'd recommend?
...disregard the question, just took a look at the part you suggested and see the glue.
again, much thanks.
abadfish66
#5 Posted : Friday, August 8, 2008 2:05:17 PM(UTC)
abadfish66
No problem
dryer leaving burn marks (Dryer Repair)
by kevnov 10/15/2008 6:31:43 PM(UTC)
