We unplugged our side by side Maytag frig for 48 hrs and then moved it to the basement. I plugged it in and nothing happens (other than the lights come on). There are no sounds, no fan, no clicking, no compressor kicking on. The only thing I did was take off the doors to move it. SO I reconnected the cable wire clip on the top of the freezer door hinge. I cleaned out the dust bunnies also. I have never had any problems with this frig before. Could something have come loose when it was moved? I thought at least the fan and compressor would immediately start up. Does anyone have any ideas? Thanks....
:) Checked my frig an hour later and everything seems to be running now.
It probably just did a defrost cycle. |
THIS FORUM IS DEAD!!!!!!! |
