spooner8
#1 Posted : Sunday, October 31, 2010 4:06:03 PM(UTC)
spooner8
I try and wash dishes on any cycle option. All that happens is the tub fills up and then it stops. Afterwards if I hit cancel it will drain just fine. The machine is only 5 months old and we only used it about ten times. Any help would be greatly appreciated!!!!!!!!
spooner8
#2 Posted : Sunday, October 31, 2010 4:12:33 PM(UTC)
spooner8
I forgot to add that it makes absolutley no noise after the tub is full. No whinning or clicks of any kind.:confused:
#3 Posted : Monday, November 1, 2010 1:25:32 PM(UTC)
Here is the tech sheet
http://manuals.frigidaire.com/prodinfo_pdf/Kinston/154768301b.pdf
It could be a loose wire since the unit is new.
More likely either the motor or the control board is shot.
Since the unit is new I would get it fixed under warranty.
If you mess with it then they could void your warranty.
Frigidaire problems (replaced control box kit) (Refrigerator & Freezer Repair)
by mcjunk 9/27/2011 10:10:27 AM(UTC)
Frigidaire Problems (diganosis help please) (Dishwasher Repair)
by mattlach 8/31/2010 10:57:32 AM(UTC)
