bryanj
#1 Posted : Thursday, August 7, 2008 11:09:28 AM(UTC)
bryanj
The washer won't spin out, checked belt, it's OK. Ran through the control panel LED checks, OK. Looking into motor invert LED check, not sure what initiates it. Is there a specific setting to be on???
abadfish66
#2 Posted : Thursday, August 7, 2008 11:29:10 AM(UTC)
abadfish66
Machine must be turned off, do you see the led blinking at all?
abadfish66
#3 Posted : Thursday, August 7, 2008 11:32:43 AM(UTC)
abadfish66
Does it agitate?
bryanj
#4 Posted : Friday, August 8, 2008 8:24:11 AM(UTC)
bryanj
abadfish66
I didn't see LED flash, not sure what the setting was. I didn't have the inverter cover off. Not sure if it will agitate, starting working on the controls before trying. Working on it again Saturday,I will make sure the machine is off. If LED doesn't flash, what next???
Thanks, Bryan
abadfish66
#5 Posted : Friday, August 8, 2008 8:54:22 AM(UTC)
abadfish66
First don't take off the invertor cover. The led on the invertor is on the right side, you should see it blinking, if it is not blinking you either have a bad invertor, which can only be replaced as the whole motor assy, or a bad inline fuse. The fuse is on the white/red wire going up the right hand side of the cabinet in the wire bundle. take off the electrical tape that is wrapped around the wire bundle, and you can check the fuse there, if open, you can replace it. But before doing anything, try this first. unplug the machine for 1 minute, make sure door lid is closed. now plug it back in and lift and close the lid 5 times, this is how you clear any error codes the invertor may have. Start a load and see what happens, if nothing then check fuse.
bryanj
#6 Posted : Tuesday, August 12, 2008 2:59:22 PM(UTC)
bryanj
abadfish66
Thanks for your help, it was the inline fuse.
Bryan
