darlingwudyoo
#1 Posted : Friday, October 29, 2010 1:05:29 PM(UTC)
darlingwudyoo
Thank You, DW allows 2" of water then shuts down. Reset, unit pumps out correctly. Please direct
darlingwudyoo
#2 Posted : Friday, October 29, 2010 1:44:04 PM(UTC)
darlingwudyoo
I have checked the float and the inlet valve. Voltage is lost at the valve just when the water starts to pool.
magician59
#3 Posted : Friday, October 29, 2010 1:51:18 PM(UTC)
magician59
Did you check the float switch, or just the float, itself?
darlingwudyoo
#4 Posted : Friday, October 29, 2010 2:17:14 PM(UTC)
darlingwudyoo
Checked for dirt and checked voltage! I am reading 120 at the valve while it is filling. When valve is closed the volatge drops and the water has not even reached the float.
magician59
#5 Posted : Saturday, October 30, 2010 9:36:48 AM(UTC)
magician59
Disconnect the valve wires. Checking for continuity, you should find it (since you say that it begins to fill. Now heat it up with a heat gun or blow dryer and check again for continuity. If you now get continuity, the valve can be ruled out as the faulty component; but if you DON'T see continuity, replace the fill valve.
