Is the NO wire the power wire or the common wire the power wire for the lid switcd. Which color is the common wire, black or tan with a red stripe?
Your model number seems to be missing the first 3 digits. They tell us who actually made the unit as Kenmore does not actually manufacture machines.
Usually the common goes to line which should be black.
If it is just a 2 connector switch (Common and Normally Open) then which wire goes where is not critical. |
THIS FORUM IS DEAD!!!!!!! |
