Replacement parts for FRIGIDAIRE LEQ1442ES0 Frigidaire/dryer | AppliancePartsPros.comHere is the tech sheet
http://manuals.frigidaire.com/prodinfo_pdf/Webster/134509400efsa.pdfAnd a manual
http://frigidaireservicetips.com/pdfs/487_2.pdfNote: I have never seen this so the following is just what I would do.
That you can restart the unit right after it shuts off is an important symptom.
Often dryer shut down is due to the motors internal thermal protect tripping but you would have to wait for the motor to cool down and the thermal protect to reset. I am assuming this is not the case.
Try to get into the diagnostics to see if the control board has stored an error code.
If no codes, the first thing I would do is check the power. (see below)
You may want to try different modes to see if it does it on all modes (auto and timed dry, with and without heat)
It could be that the board monitors the temperature and is shutting down/erroring out due to the no heat condition.
If power is good I would check the heating element, the hi-limit thermostat, the thermal limiter and the thermistor for resistance.
Try flipping the breaker off/on slowly a couple times, sometimes you can loose half the line without actually tripping the breaker.
If this does nothing, check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
[COLOR="Red"]Be careful as 240 volts is lethal !!! [/COLOR]
Sorry that I cannot be more helpful but hopefully the above will be of some use.
