3 Pages<123>
manager3
#11 Posted : Monday, August 4, 2008 12:53:26 PM(UTC)
manager3
Also, how can I be sure my cap is good? all I have is an ohm meter with rx1, rx10, rx100.
abadfish66
#12 Posted : Monday, August 4, 2008 1:29:56 PM(UTC)
abadfish66
Yes, it will kill everything
manager3
#13 Posted : Tuesday, August 5, 2008 4:29:11 AM(UTC)
manager3
Ok. So if I replace the TCO and the diode, that'll probably do it? please also give me your part# for the diode. Thanks!
abadfish66
#14 Posted : Tuesday, August 5, 2008 8:54:51 AM(UTC)
abadfish66
You most likely don't need a diode, you can't check a diode with just an ohm meter, you wont get any reading, and from your description, your cap is good also, replace the tco and go from there.
abadfish66
#15 Posted : Tuesday, August 5, 2008 8:56:03 AM(UTC)
abadfish66
manager3
#16 Posted : Wednesday, August 6, 2008 12:21:02 PM(UTC)
manager3
Hey abadfish66, Black the trim on the right side control panel also broken. Is this replacement available?
abadfish66
#17 Posted : Wednesday, August 6, 2008 12:24:25 PM(UTC)
abadfish66
Yes, but I will need the complete model# to get you the part#
manager3
#18 Posted : Wednesday, August 6, 2008 12:31:24 PM(UTC)
manager3
it reads exactly: J VM140 001
abadfish66
#19 Posted : Wednesday, August 6, 2008 1:12:19 PM(UTC)
abadfish66
Sorry manager3 looks like the plastic trim is no longer available....Here is the GE part# maybe you can find one somewhere...WB7x1836
manager3
#20 Posted : Saturday, August 9, 2008 8:59:44 AM(UTC)
manager3
hello abadfish. Received parts, gottem in and plugged her up. Fan immediately started running however, no controls........ your thoughts?
Guest (16)
3 Pages<123>
