MikeTD
#1 Posted : Wednesday, August 6, 2008 9:08:20 AM(UTC)
MikeTD
I have a commercial Maytag coin operated washer that will not work. The "unbalance load" light is on and when I drop quarters into the mechanism I don't even hear the timer running. I have attached a schematic and circled (in red) where the Unbalanced Load light is. There doesn't appear to be any "unbalance" switch. I was told you can reset the unbalance condition by opening and closing the lid; I've done this but still the problem persists. Any thoughts? Thanks
File Attachment(s):
washer schematic.pdf (131kb) downloaded 17 time(s).
southerngates
#2 Posted : Monday, May 31, 2010 11:11:37 AM(UTC)
southerngates
Mike, I think we are having the same problem as you. Did you ever get a reply or did you get the problem fixed? If you could let us know, we would appreciate it.
MikeTD1
#3 Posted : Tuesday, June 1, 2010 3:49:16 AM(UTC)
MikeTD1
As I recall it turned out that I needed a new timer assembly for the washing machine. I installed it and everything has worked fine since. Good luck, hope this helps.
southerngates
#4 Posted : Tuesday, June 1, 2010 9:36:57 AM(UTC)
southerngates
Thanks, we will give that a try. We keep replacing parts to no avail.
