ctcashatt
#1 Posted : Monday, October 25, 2010 10:01:27 AM(UTC)
ctcashatt
Our dryer dries good, but the heat cuts off too soon. For example, if yoiu put it on 70 minutes by the time it gets to 35 minutes remaining it is already cooling off. Could this be the timer or thermostat or what?:confused:
sidfink43
#2 Posted : Wednesday, October 27, 2010 4:33:03 PM(UTC)
sidfink43
Try replacing the timer if the machine otherwise operates correctly.
Here is the part
Part number: AP3859587
If it does not fix things you can return it, see the returns policy for requirements.
