leokaplin
#1 Posted : Friday, October 22, 2010 9:49:49 AM(UTC)
leokaplin
need expert...Freezer is very cold.. lower fridge is warm/a little cold.. fan in freezer does not turn on at all.. fan at rear bottom always on.
What could be wrong?
#2 Posted : Friday, October 22, 2010 12:55:18 PM(UTC)
Originally Posted by: leokaplin Go to Quoted Post
...fan in freezer does not turn on at all...
Sounds like the evaporator fan motor (in the freezer) has gone bad.
- The evaporator fan motor Part number: AP3798650
leokaplin
#3 Posted : Saturday, October 23, 2010 4:58:14 AM(UTC)
leokaplin
HOw can i verify this?
with ohmeter or any other way.. i do have access to it and can take it out.
Leo
#4 Posted : Saturday, October 23, 2010 3:57:35 PM(UTC)
Leo,
Check for 120 VAC to this motor while the compressor and the fan on the back are on.
If there is proper voltage, the motor is bad.
leokaplin
#5 Posted : Sunday, October 24, 2010 1:27:56 PM(UTC)
leokaplin
how do i know if the compress is on.. there is no other noice coming from the frigde. the fan at the bottom rear is always on and never shuts off.
#6 Posted : Tuesday, October 26, 2010 1:07:20 PM(UTC)
... the fan at the bottom rear is always on and never shuts off...
This fan is next to the compressor. If you touch the compressor, you'd feel it's vibrating.
leokaplin
#7 Posted : Wednesday, October 27, 2010 5:42:48 AM(UTC)
leokaplin
the compressor is not making any noice and not vibrating...
#8 Posted : Wednesday, October 27, 2010 4:33:50 PM(UTC)
Did the fan next to the compressor run at the time you checked the compressor?
Is the freezer still very cold?
leokaplin
#9 Posted : Thursday, October 28, 2010 4:27:12 AM(UTC)
leokaplin
The Freezer is very cold.. i took off the panel and there is frost on the coil.. the fan in the freezer never runs, the fan at the rear bottom always run.. will check today if there is 120V to fan.. should there be 120V there all the time?
Cafe fridge keeps warming up. Help! (Refrigerator & Freezer Repair)
by Guest 6/28/2024 8:33:23 PM(UTC)
Help! Washing machine on repeat rinse cycle (Washer Repair)
by cali.poppy 4/29/2024 9:08:28 AM(UTC)
HELP!!! Maytag Lat9604abe leaking from weeping holes in tub seal (Washer Repair)
by gocanada72 3/18/2024 5:53:29 AM(UTC)
Help! Washer chirping noise (Washer Repair)
by Guest 10/8/2023 6:40:46 AM(UTC)
Troubleshooting Help!! (Dishwasher Repair)
by Guest 6/20/2023 1:14:28 PM(UTC)
Kenmore Dryer, Help! (Dryer Repair)
by C DeBardeleben 4/18/2023 3:58:41 PM(UTC)
Maytag Dryer MGD7230HW2 LP CONVERSION HELP!! (Dryer Repair)
by prodigey 10/14/2022 3:54:00 AM(UTC)
KitchenAid Artisan unknown problem. Please help! (Blender Repair)
by fakupos 5/17/2022 8:00:10 AM(UTC)
Mah2400aww Maytag Door Boot Door Diaphragm Discontinued, Help! (Washer Repair)
by DIY_Vee 3/4/2022 7:34:13 AM(UTC)
Ice maker dispenser will not stop running - help! (Refrigerator & Freezer Repair)
by Guest 1/30/2022 7:11:17 PM(UTC)
Maytag Bravos MCT HELP!!!!! (Washer Repair)
by Guest 10/23/2021 7:31:14 AM(UTC)
Help! Does motor need to be replaced or cleaned out? (Dishwasher Repair)
by connellh 4/30/2021 8:36:32 AM(UTC)
Kenmore not cooling - Can't get a replacement fridge HELP! :) (Refrigerator & Freezer Repair)
by shorton 11/9/2020 11:33:04 AM(UTC)
Help! GE Profile Electric Oven PT916SMSS (Oven Repair (including Ranges and Cooktops))
by Marsa 5/9/2020 8:36:48 AM(UTC)
HELP! Need clip or nut for Foot on Frigidaire Gas Range (Oven Repair (including Ranges and Cooktops))
by RichardKY 5/5/2020 6:43:52 AM(UTC)
