nguyenhung77478
#1 Posted : Tuesday, October 26, 2010 7:45:25 AM(UTC)
nguyenhung77478
My refrigerator freezes up every 5,6 days.
I have changed control assy temp but it did not help.
Is it possible the Heater & Therm problem?
I opened it, it looked normal. In the past it burned out once few years ago (it turned out my Frig was recalled due to overheat of an electric component. Maytag already changed the incriminating component).
What would you suggest to resolve this problem?
Thank you
#2 Posted : Tuesday, October 26, 2010 9:35:21 AM(UTC)
Here is the parts breakdown
Replacement parts for MAYTAG MZD2766GES Ref - SXS/I&W | AppliancePartsPros.com
Sorry but more info would be helpful.
[COLOR="Blue"]My refrigerator freezes up every 5,6 days.[/COLOR]
What freezes up?
What symptoms do you have?
[COLOR="Blue"]
I have changed control assy temp but it did not help.[/COLOR]
What control assy? The adaptive defrost control, the main thermostat etc.?
[COLOR="Blue"]Is it possible the Heater & Therm problem?[/COLOR]
Depends, if it is a defrost problem then yes.
tinktank99
#3 Posted : Tuesday, October 26, 2010 11:18:09 AM(UTC)
tinktank99
check your thermal cut out, small round disk looking thing attached somewhere near the heater. if the center looks pushed out that could be the problem (it is a silver disk with a rubbery looking top...usually red black or blue) or your heater could be bad or the defrost timer.
nguyenhung77478
#4 Posted : Tuesday, October 26, 2010 4:33:58 PM(UTC)
nguyenhung77478
The evaprator freezes up so the fan could not move the air to the refrigerator compartment.
The part I changed is Control assy., temp.
Part Number: AP4070269 made by WHIRLPOOL
I think the defrost is not working but not sure.
Do I have to change the heaterHeater & therm. assy
Part Number: AP4069923 ?
Thank you.
#5 Posted : Wednesday, October 27, 2010 1:55:08 AM(UTC)
[COLOR="Blue"]The evaprator freezes up so the fan could not move the air to the refrigerator compartment.
I think the defrost is not working but not sure.[/COLOR]
Yes, it does sound like a defrost problem
[COLOR="Blue"]The part I changed is Control assy., temp.
Part Number: AP4070269 made by WHIRLPOOL[/COLOR]
This part will not repair a defrost problem, it controls the units temperature.
[COLOR="Blue"]Do I have to change the heaterHeater & therm. assy
Part Number: AP4069923 ?[/COLOR]
This may fix the problem but I would do some troubleshooting first.
There is a 99.999% chance that either the heater & therm assembly OR the adaptive defrost board (Item 13 in Section 2) is the culprit.
First remove the evaporator cover in the freezer so you can see the coils.
Do not let them de-ice.
If they are heavily iced/frosted over you have a defrost problem.
If yes.
Manually force a defrost cycle.
Here is a link to forcing a defrost the first and last paragraphs on the page are for Maytags.
http://www.applianceaid.com/adaptive_defrost.html
With this unit I think to force a defrost, with the unit on and the compressor running turn the temperature control on/off 3 times in 6 seconds. The compressor and fans should then turn off with the temperature control in the on position, you are now in a defrost cycle.
Now check the defrost heater to see if it is on.
Be careful you do not want to burn your fingers.
If the heater is on then the board needs replacing.
If not on.
Unplug the unit.
Disconnect the heater & therm and measure across the heater for continuity, usually around 20 ohms or so.
If the heater is OK
Measure across the defrost thermostat (Item in Section ) and measure it, should be 240,000 ohms when frozen. Note that it opens just above freezing so must be frozen to check it. Also inspect it, if it is bulged at all replace it even if it measures OK.
If both the above are OK then odds are the board is toast.
Best way to test this is a live test to see if you have 120 volts across the heater/defrost thermostat combo.
Guest (4)
