Originally Posted by: mnk  Tried to get into it. Having trouble with password. Will try Tomorrow . THANKS Mike:) Mike, Password ? You should have been able to click and go ? As a last resort, Do you have a fax number, and can I have it to fax the sheets to you ? Until I figure out what I'm doing wrong. :confused: :confused: :confused:
Originally Posted by: Joe / APP Team  Mike,
Password ?
As a last resort,
:confused: :confused: :confused: Mike, you may want to try this scan0001.pdf (803kb) downloaded 11 time(s).
Joe Lets try the Fax i-419-673-8066 my Work fax. Thanks for your time and effort's. You really have been helpful. Work here in Ohio from 9-3. Mike:)
Originally Posted by: mnk  Joe Lets try the Fax i-419-673-8066 my Work fax. Thanks for your time and effort's. You really have been helpful. Work here in Ohio from 9-3. Mike:) Mike, Just faxxed the 8 page tech sheet to: 1-419-673-8066 Thanks, :cool: :cool: :cool:
GOT IT . THANK YOU. This will Help. Thanks. We redone the Plug the washer is plugged into thinking it might have something to do with the Washer Chord plug being inserted a little sideways but still plugged in to the socket all the wayPLUS the Wire going to the plug-in for the washer didn't have the Ground like the New wiring Does when you wire a house. Got an Old house with old two wire running to outlets. Thought maybe that was why we weren't getting a code, the electricty gets funky. Thanks for all you help. we'll try it and see if it washes. THANKS AGAIN. Mike:) :rolleyes:
Originally Posted by: mnk  GOT IT . THANK YOU. This will Help. Thanks. We redone the Plug the washer is plugged into thinking it might have something to do with the Washer Chord plug being inserted a little sideways but still plugged in to the socket all the wayPLUS the Wire going to the plug-in for the washer didn't have the Ground like the New wiring Does when you wire a house. Got an Old house with old two wire running to outlets. Thought maybe that was why we weren't getting a code, the electricty gets funky. Thanks for all you help. we'll try it and see if it washes. THANKS AGAIN. Mike:) :rolleyes: Mike, We're glad, Sorry for the delay and all the mis communication. I've got a plan, and I may get things going with the system. In most cases a decent power supply, usually won't create a lot of problems with a basic washer. However, when it comes to PCB's and DC voltages, it can reak havoc, a proper power supply is pretty much imperative for proper operation. Keep in touch, and let us know how things go. :) :) :)
Thanks - Have a GREAT DAy. Mike;)
Originally Posted by: mnk  Thanks - Have a GREAT DAy. Mike;) You TOO, :cool: :cool: :cool:
