Mike N
#1 Posted : Monday, October 25, 2010 7:40:54 PM(UTC)
Mike N
Have a Kenmore Series 70 dryer with no heat. Replaced heating element, but it didn't work. Checked power to element and I have no voltage to heating element (motor is blowing fine, drum tumbles fine, etc). Thermal Fuse is closed, so that is not the issue. What other areas can I check to determine lack of power to heating element.
#2 Posted : Tuesday, October 26, 2010 2:34:42 AM(UTC)
Replacement parts for KENMORE 11062722100 | AppliancePartsPros.com
[COLOR="Blue"]Which thermal fuse did you check?[/COLOR]
There are 2 of them.
The one on the blower assembly kills power to the unit.
The one on/close the heater (forth item down in the parts listing) kills power to just the heating coil.
See below "[COLOR="SeaGreen"]Heater thermal cut-off (fuse)[/COLOR]"
Try flipping the breaker off/on slowly a couple times, sometimes you can loose half the line without actually tripping the breaker and the heater requires the full 240 volts.
If this does nothing, check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
Be careful as 240 volts is lethal !!!
If it is blown you have to find out what caused it to go.
Note: that sometimes they do just blow on their own but changing it without checking other things is a gamble. I beleive richappy (another regular poster on this forum) has done a study on thermostats and found a wide variation of actual trip point and what is specified.
Check the heating coil.
Unplug the unit and both wires to the coil.
Check it with a meter, should be around 12 ohms.
Then check from each side of the coil to the case/frame, both should be infinite ohms (open). If not the coil may have sagged or broken and is touching the case. This can cause it to run on high and the thermostats cannot regulate it.
If the above is OK then you will also have to replace the hi-limit as it should have regulated the temperature so the fuse did not blow.
You still have to find out why it blew.
Check that the belt is OK.
Check the seals (drum etc) in the unit. The air is pulled over the heating coils, through the drum and pushed out the exhaust. So any large seal leak will pull in room air and the cycling thermostat on the blower will run the unit hot.
Check that the lint filter is not coated with fabric softener residue which greatly reduces air flow.
Check/clean your vent system.
Check/clean the blower wheel.
If all OK you may want to replace the cycling thermostat as it's contacts may not be opening (welded shut).
Mike N
#3 Posted : Tuesday, October 26, 2010 7:45:33 AM(UTC)
Mike N
Thanks Denman.
After I wrote the posting, I realized the Temperature Thermal fuse that you referenced as your 2nd area to check was blown and hence, I had no power to the heating element (240 volts supply was fine). When the part arrives, I'll take a look at your other suggestions and hopefully this will take care of the issue.
Mike
