AppliancePartsPros.com
Appliance Repair Help
Washer Repair
Is it the motor control unit?? Thanks in advance
will not spin out the clothes. Diagnostic test results in no high speed spin. the drum will move back and forth during test but will not spin. Need help. Is it the Motor control unit?
Originally Posted by: BDR89  will not spin out the clothes. Diagnostic test results in no high speed spin. the drum will move back and forth during test but will not spin. Need help. Is it the Motor control unit? No. Here is what I want you to do. Unplug the washer, and pull it away from the wall. Then lean the washer back and rest it on the wall. Thenn take the screws off the bottom panel. Once the panel is removed, the pump is right up front, and in the middle. Unscrew the pump cover, and pull the filter out. If it is all full of junk, clean it out, put it back together, and put the timer on a drain, and spin cycle, and let it go, and see if it spins. Let me know how it goes. Tom ApplianceEducator.com
Washer Repair
