rawhide 007
#1 Posted : Monday, October 25, 2010 1:53:48 PM(UTC)
rawhide 007
we have a OP code on the washer it will not let us proceed to locking the lid what do we to fix it.
rawhide
dh1200s
#2 Posted : Monday, October 25, 2010 2:25:35 PM(UTC)
dh1200s
rawhide
Hey rawhide, I’m an owner and do all my own work on the machine. Most times this issue is caused by loss of signaling thru the Left Hand Lid Lock.
1st check for a Lid Magnet out of position. This is an easy check if you have a couple key holder magnets or a similar magnet that you can place over the Left side grey lid bumper. Let’s see if you can close the Magnetic Reed Relay switch with an external magnet and send +12VDC up to the Control Board and clear the “OP” error code.
If that doesn’t clear the “OP” error code we will need to remove the Left Hand Lid Lock and check to see if corrosion is part of the issue. Because of its proximity to that nasty bleach dispenser it will cause issues.
See the 2nd and 3rd pic’s.
If you are going to DIY you will need the Service Manual for support if so e-mail me, My V-Card has my e-mail adr............Dick
dh1200s attached the following image(s):
rawhide 007
#3 Posted : Monday, October 25, 2010 4:16:58 PM(UTC)
rawhide 007
Dick: I am not able to find your v-card for e-mailing you
rawhide pleasee-mail rll53@woh.rr.com
dh1200s
#4 Posted : Monday, October 25, 2010 6:37:55 PM(UTC)
dh1200s
rawhide I sent you some info. Let's see if the external magnet will clear the OP error code. If not we will move to the next level of troubleshooting. Dick
MAYTAG NEPTUNE TL FAV6800AWW WASHER (Oven Repair (including Ranges and Cooktops))
by suez 1/1/2020 11:39:52 AM(UTC)
Maytag Neptune TL (Washer Repair)
by tupkat 6/23/2015 5:25:32 AM(UTC)
Maytag Neptune TL 6800AW--help with where to next (Washer Repair)
by jlwieland 4/27/2015 6:57:24 PM(UTC)
Won't drain: Maytag Neptune TL FAV6800AWW (Washer Repair)
by bcomo 10/22/2012 6:58:43 AM(UTC)
Maytag Neptune TL washer (Washer Repair)
by kwall139 6/14/2012 7:53:10 AM(UTC)
Maytag Neptune TL Stops in Wash (Washer Repair)
by mbacko1 6/1/2012 6:56:26 PM(UTC)
Maytag Neptune TL (FAV6800AWQ (Washer Repair)
by SkidSTG 11/21/2010 8:58:03 AM(UTC)
Maytag Neptune TL - Will Not Spin (Washer Repair)
by george4051 9/12/2010 6:04:10 AM(UTC)
Maytag neptune tl (Washer Repair)
by owner 8/10/2010 7:22:19 AM(UTC)
by Dwheeler 7/24/2010 8:46:39 AM(UTC)
Maytag Neptune TL Cycle Descriptions (Washer Repair)
by mljuw89 2/3/2010 12:59:44 PM(UTC)
Maytag Neptune TL Top-Load - Fabric Softener Won't Dispense (Washer Repair)
by kendra65 12/14/2009 10:49:54 AM(UTC)
Maytag Neptune TL OD code (Washer Repair)
by Curiouscleaner 11/30/2009 9:29:33 AM(UTC)
Maytag Neptune TL overfills (Washer Repair)
by Plachta 10/2/2009 3:16:10 AM(UTC)
by Plachta 10/2/2009 2:33:36 AM(UTC)
