mpeccleston
#1 Posted : Sunday, October 24, 2010 7:54:23 AM(UTC)
mpeccleston
The start button makes it's usual noise when pressed but the motor will not start. Every once in 5 times I try it works. Any ideas?
magician59
#2 Posted : Monday, October 25, 2010 7:02:51 AM(UTC)
magician59
If it's on a touch pad, I would suspect the touch pad is worn. If it's a separate start button, It is probably a weak start switch or relay.
