gfv70
#1 Posted : Thursday, March 27, 2008 8:44:15 AM(UTC)
gfv70
Where do i gain access to the drain tube its clogged, and water is pooling at the bottom of the unit, is it in the refrigerator at the top or the back of the freezer?
#2 Posted : Thursday, March 27, 2008 4:55:27 PM(UTC)
Remove the floor in the freezer. Remove the back panel.
The drain is located under the evaporator coil and, most likely it's frozen.
You can use a hair dryer to defrost it and hot water to run through.
Here are the break down diagrams for the Roper refrigerator Model RT21LMXKQ02
gfv70
#3 Posted : Friday, March 28, 2008 4:48:30 AM(UTC)
gfv70
Thanks Gene
jb4
#4 Posted : Sunday, October 24, 2010 7:16:57 PM(UTC)
jb4
Views messages in topic : 1
exactly right. You have to take off the back panel and there is a metal strip on the bottom. Just right of center is the drain hole that connects to the drain tube that leads to the bottom holder tray. I used a hair dryer combined with microwaved hot water for a period of 30 mins. My drain hole was frozen over as was most of the base of my freezer. Thanks for all the info.
#5 Posted : Tuesday, October 26, 2010 1:22:15 PM(UTC)
You are welcome. Thank you for the feed back.
KitchenAid drain tube frozen solid (Refrigerator & Freezer Repair)
by jonathan.howes@gmail.com 12/10/2022 9:49:06 AM(UTC)
Heater Wire: drain tube heaters and door rim heater assembly (Refrigerator & Freezer Repair)
by OzarkMcCoy 11/18/2019 12:11:58 PM(UTC)
Drain Tube replacement part? (Refrigerator & Freezer Repair)
by RPMerg 6/14/2014 6:58:57 AM(UTC)
Drain Tube (Refrigerator & Freezer Repair)
by jnovak64@hotmail.com 4/6/2014 1:09:52 PM(UTC)
Freezer dripping into fridge, Can't get to drain tube check valve?? (Refrigerator & Freezer Repair)
by g20zoom 3/1/2014 6:57:48 PM(UTC)
clogged drain tube (Refrigerator & Freezer Repair)
by tommy cochran 5/29/2012 11:34:35 AM(UTC)
drain tube freezeing up (Refrigerator & Freezer Repair)
by ccpccart 5/2/2011 12:55:32 PM(UTC)
Drain Tube Access (Refrigerator & Freezer Repair)
by Afishh 9/11/2010 6:17:37 PM(UTC)
Drain tube clogged (Refrigerator & Freezer Repair)
by dojo55 4/11/2010 9:22:12 AM(UTC)
by billhds 12/11/2009 6:37:20 AM(UTC)
Where is the drain tube/water freezing bottom of freezer (Refrigerator & Freezer Repair)
by GertieMae3 9/22/2009 7:26:04 PM(UTC)
Where is GE refrigerator freezer drain tube (Refrigerator & Freezer Repair)
by mastone3 9/20/2009 3:04:27 PM(UTC)
Amana top freezer how do you get to the drain tube (Refrigerator & Freezer Repair)
by jdmyers19024 9/16/2009 2:57:27 PM(UTC)
Kenmore fridge leaks water into fridge instead the drain tube (Refrigerator & Freezer Repair)
by skg 8/13/2009 11:27:53 AM(UTC)
Drain Tube Help (Refrigerator & Freezer Repair)
by crappieman 7/2/2009 5:08:55 PM(UTC)
