My husband repaced the oven sensor part # 12001656 . The panel membrane is on back-order until Nov. 22. The appliance tech guy said we needed oven sensor and touch pad. I thought hubby could do it. Anyway we replaced the oven sensor(had to change connector) and add wire nut. because connector did not match. Turned power back on and oven still shows F5. Do we have to reset the oven? We tried doing test and holding Stop and Cook time....still no luck. Please help us. Thank you
Originally Posted by: lreinkes  My husband repaced the oven sensor part # 12001656 . The panel membrane is on back-order until Nov. 22. The appliance tech guy said we needed oven sensor and touch pad. I thought hubby could do it. Anyway we replaced the oven sensor(had to change connector) and add wire nut. because connector did not match. Turned power back on and oven still shows F5. Do we have to reset the oven? We tried doing test and holding Stop and Cook time....still no luck. Please help us. Thank you The problem is the clock control board. (ERC Board) Tom Appliance Educator, Appliance Parts, Washer and Dryer Parts, Refridgerator and Freezer Parts, Stove and Oven Parts
