robmints
#1 Posted : Saturday, August 2, 2008 12:08:21 PM(UTC)
robmints
Hi.
Duet Mod#GHW9200LQ, Ser#CSM 0905651, Type#199 AWM 076BL
First it would do nothing, push any button or combo and nothing. I took the door switch out and it did not have any wires hanging off or springs sticking out so I put it back in. Then I kept pushing buttons and turning knobs and with the selector sw on normal the timer alternates between 1:55 and :40 and the selector lights change from Sanitary to Normal as the timer changes. The other lights to right of that look like they are setting the launch codes. We did have a storm last night but no close lightning. Only thing we have done since we have had it was put new baffles on (with your help).
Any thoughts of where to start or likely causes so we can get her going again? Thanks.
robmints
#2 Posted : Thursday, August 7, 2008 4:33:52 PM(UTC)
robmints
I think I have a mouse problem. They ate the ribbon cable wires. It's ribbon cable from the ccu to the control panel. I could not see any evidence of a problem until I took the control panel off.
