jlewin
#1 Posted : Sunday, February 21, 2010 6:50:23 AM(UTC)
jlewin
Dishwasher is leaking from the front right bottom part of the dishwasher door. The gasket looks fine though depressed slightly in the right bottom corner. Any ideas??
joelj
#2 Posted : Thursday, June 10, 2010 10:47:11 AM(UTC)
joelj
My Triton XL has exactly the same problem - gasket replaced but still leaked, then repairman said "I guess I should take it apart" he took off the front metal panel of the washer and the answer was obvious - a strema of old soap and water coming down from the exhaust vent on the upper front right of the washer - he said he'd call back to see if he could fix it, but no word yet.
rplkate
#3 Posted : Thursday, October 21, 2010 11:17:27 AM(UTC)
rplkate
I had the same problem, called the repairman, who charged me $90 to remove the small plastic vent cover inside the door and rinse it out of soap residue. Try that.
