The oven was fine this morning...power went out and now the digital screen won't work...the elements work fine, but the screen just says 'off' if I try to set the clock or start up the oven or try anything!! We did try unplugging it for 15 mins, but still no luck..any suggestions or if someone has a manual would be greatly appreciated!! Thanks!
