notsohandy
#1 Posted : Tuesday, October 19, 2010 8:16:41 AM(UTC)
notsohandy
Have an eight yr.old Kenmore dishwasher ,how do I replace the heating element?
#2 Posted : Wednesday, October 20, 2010 4:19:36 AM(UTC)
Heater
Part number: AP4424048
Nuts
Part number: AP3965251
I am assuming that you have troubleshot the unit and are confident that the e;lement is toast. As the thermostat and the contriol board could also give a no heat symptom.
Remove power/unplug the machine.
Remove the kick plate.
Remove the wires from the element.
Undo the nuts
Replace the element.
Be careful when undoing the nuts as they are not very robust.
This may also help though I am not sure if it is an exact match to your unit
http://frigidaireservicetips.com/pdfs/484_2.pdf
Guest (4)
Dryer not heating enough after replacing heat element (Dryer Repair)
by lfshadow 8/12/2013 6:33:40 PM(UTC)
GE glass top oven popped after replacing heat element (Oven Repair (including Ranges and Cooktops))
by eksta 12/20/2012 4:56:27 PM(UTC)
Replacing heat element.. (Dryer Repair)
by Mark D. Scherer 3/11/2009 3:35:40 PM(UTC)
