TomH
#1 Posted : Wednesday, July 30, 2008 7:47:31 PM(UTC)
TomH
I just ordered in a replacement EOC for my 4 yr old Frigidaire FEF366CCB. It's exactly the same piece, except it is missing 2 terminals and a relay (In fact, it's the relay that blew are the ones not supplied on your board).
Apparently, it's a different piece - the one your sent said 5301 Rev D. while the orginal has 5306 Rev D. There is no alternate part shown for this piece, however, you can see the missing terminals/relay at this site and comparing it to your own picture:
Their picture (and the one we need): http://www.************.com/Sma...ID=1036364&PPStack=1
(for some reason, this post is editing the url above, please insert Repair Clinic (one word) for the asterisks to see correct part)
Your picture:
Model FEF366CCA
I don't know what's going on with this. Is there a way to bypass the missing relay? If not, what can you tell me? Any help would be appreciated.
Thanks -
Tom
#2 Posted : Thursday, July 31, 2008 7:42:46 PM(UTC)
Hi Tom,
The ranges with model numbers FEF366CCA and FEF366CCB are different and have a different EOC's (electronic oven control aka clock).
The part number for the EOC you purchased is AP3672811 and the right part number for your range EOC is AP3561834
If you did not install this part, you can exchange it for the right one. Just call the customer service (877-477-7278).
When you are searching for replacement parts it is very important to match up the model number exactly. If you did not find your model number during the search, the best way is to call the customer service and they will help you.
