whsydddy9
#1 Posted : Monday, October 18, 2010 4:20:20 PM(UTC)
whsydddy9
what is the breaker and wire size required to run Model number JENN-AIR SCE30600B Range ? the distance to the breaker box is approximately 30 feet. I was told this is a 6800 watt range, 240 volt.
Keith Hocky
#2 Posted : Monday, October 18, 2010 4:33:26 PM(UTC)
Keith Hocky
Most ranges use a 2 pole-50 amp breaker, #6 aluminum range cable (3 individual wires with ground) or #8 Cu 4 wire. Either will do for a 30' distance. To be sure you have the right size wire do a little math.
Wattage of the Range= Current x Voltage
soooo... divide the Wattage by the voltage to get your current flow.
Then round up for safety! If the current comes out to 42 Amps use a 50 amp breaker.
Hope this helps!
whsydddy9
#3 Posted : Monday, October 18, 2010 4:46:06 PM(UTC)
whsydddy9
Thank You...I appreciate the info!
service wire and breaker size (Oven Repair (including Ranges and Cooktops))
by whsydddy9 10/18/2010 4:19:35 PM(UTC)
