s.mbatykefer@yahoo.com
#1 Posted : Saturday, October 16, 2010 10:38:17 AM(UTC)
dryer was working fine today till the power went off then came back on,went to start it again and it worked,then i turned it off for a minute or two then went to start it again and it will not turn on!!!!:mad: i took the back off and checked to see if there was anything that i could notice was wrong and i reset the breaker also.
sidfink43
#2 Posted : Monday, October 18, 2010 3:58:45 PM(UTC)
sidfink43
You will need a multi meter to see that you are getting power to the dryer even though you reset the breakers, since they could be defective.
If they are ok, and power is coming into the machine you need to try to trace the wiring to see if their is a break. There should be a wiring diagram inside the console.
