tack1
#1 Posted : Wednesday, July 30, 2008 2:20:35 PM(UTC)
tack1
I Have No Gas Coming Out For Oven,how Ever The Brioler And Top Range Works Fine.doe I Need The Valve?
#2 Posted : Thursday, July 31, 2008 2:31:09 PM(UTC)
Most likely the problem is a bad oven igniter. Even if it does glow, the current drawn by the igniter is not enough to open the gas valve.
- The part number for the igniter is AP205873
Here are the break down diagrams for the Maytag range Model MGR5755BDB
