Replacement parts for MED5800TW0 models | AppliancePartsPros.comDid you check the heating element with meter or see that it was broken before replacing it?
OR
Did you assume it to be the most likely cause and so re[placed it?
[COLOR="Blue"]Is there something that controls te electricity to the element that can be replaced[/COLOR]
Yes; there are a number of things.
Main thermostat (Item 8 in Section 3)
Thermal cut-off (fuse) (Item 9 in Section 3). Note: it includes a hi-limit thermostat. The hi-limit should have regulated the temperature so the thermal cut-off did not blow so it is assumed that it also did not function correctly. If you had a grounded element then the thermostat could not regulate the temperature and that is why the thermal cut-off blew.
There are other things but the above are the most common.
Try flipping the breaker off/on slowly a couple times, sometimes you can loose half the line without actually tripping the breaker and the heater requires the full 240 volts.
If this does nothing, check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
[COLOR="Red"]Be very careful as 240 volts is lethal!!![/COLOR]
