nugentc
#1 Posted : Saturday, October 16, 2010 2:32:17 PM(UTC)
nugentc
We just got a water line installed. Initially when I hooked it up I could hear the icemaker making/dumping ice. But then the housing of the water dispenser started to leak a little (not the tube/dispenser itself but behind the plastic housing). I replaced the water inlet valve and that seemed to fix the leaking. Stuff in the icemaker area was all frozen over, so I defrosted some of it with a hairdryer.
Everything seems fine except that now it won't dump ice on its own unless I pull the plastic sensor arm/paddle forward. Once I pull it forward it senses that the bin is not full, dumps, and makes ice again, but the arm never returns to the forward position for days at a time until I pull it forward myself.
Any ideas what might be going on?
Thanks in advance! (Brand is GE, not Frigidaire)
applianceman
#2 Posted : Saturday, October 16, 2010 2:40:06 PM(UTC)
applianceman
There is a spring that is most likely out of place. It could be broken but typically it will just be out of place. There is a hole in the arm and a hole in the icemaker. One end if the spring fits into the hole in the arm and the other in the icemaker. There is a picture on this page that shows what I am talking about. GE Icemaker Repair Guide
nugentc
#3 Posted : Saturday, October 16, 2010 2:51:57 PM(UTC)
nugentc
Awesome, that sounds like it could be the problem. I'll go check it out in a little bit. Thanks so much!!!
nugentc
#4 Posted : Saturday, October 16, 2010 3:06:29 PM(UTC)
nugentc
It seems that this was the problem. The spring was out of place. Thank you so much. I'll definitely be back here in the future if I need to order a part. Thanks again.
