Moose
#1 Posted : Wednesday, July 30, 2008 10:46:28 AM(UTC)
Moose
The top oven is not working, when you turn it on the light inside will dim then click and brighten again?????????????:confused:
#2 Posted : Wednesday, July 30, 2008 8:07:16 PM(UTC)
Hi Moose,
In which mode did you use it?
Moose
#3 Posted : Thursday, July 31, 2008 5:33:26 AM(UTC)
Moose
On all modes last night I took apart the front top panel just to look and tested the fuses one is burnt out, any idea why it would blow the fuse?????????? and also I put the good fuse in for the top oven it works like it should? Thanks Rick
#4 Posted : Thursday, July 31, 2008 11:58:11 AM(UTC)
I can not tell why the fuse got blown. One of possibilities (one of pretty common) is just age of the fuse. Nothing last forever.
Moose
#5 Posted : Thursday, July 31, 2008 12:40:28 PM(UTC)
Moose
OK thanks, i will put a new fuse in and go from there. thanks Rick:rolleyes:
