Shinobi13
#1 Posted : Saturday, October 16, 2010 10:57:23 AM(UTC)
Shinobi13
So I replaced the filter on this fridge. I was getting water and ice just fine. Followed the instructions, but now there is no water going to the door or ice maker. I tried bleeding the line for ten minutes. When I push the water dispenser switch, I hear it working but no water coming out. I checked the lines, they are empty. I pulled the fridge from the wall and opened and closed the water valve. I took the hose off the valve and opened and closed it again. Lone behold, no water. Why would it not be putting out water all the sudden?
Any ideas? Thanks.
No water after changing filter (Refrigerator & Freezer Repair)
by CBH 3/7/2009 11:50:50 AM(UTC)
