I am not sure but I think I need a new thermostat for the oven. It is burning everything. Seems it gets too hot. My meatloaf was burned in 15mins. and the temp was set at 350%. Burning my cakes and pies and I am using the upper level. Does it need a new element or thermostat? I am afraid to self clean it for fear it will explode the oven coil element. Thank you. DD
:confused: Originally Posted by: DDHauto I am not sure but I think I need a new thermostat for the oven. It is burning everything. Seems it gets too hot. My meatloaf was burned in 15mins. and the temp was set at 350%. Burning my cakes and pies and I am using the upper level. Does it need a new element or thermostat? I am afraid to self clean it for fear it will explode the oven coil element. Thank you. DD
THIS FORUM IS DEAD!!!!!!! |
