John Scaletta
#1 Posted : 17 years ago
John Scaletta
The door handle has broken off my microwave. The top screw is exposed and the bottom screw is buried within the door window. How do you find the bottom screw to replace the handle?
#2 Posted : 17 years ago
Hi John,
In order to get access to the door handle screws you have to remove the inner door panel. It is mounted with a few tabs and you have to be careful not to break them.
- The part number for the black door handle is AP2021171
Here are the break down diagrams for the GE microwave Model JVM1339BW03 (basic model number JVM1339).
piabobky
#3 Posted : 15 years ago
piabobky
The frame around the windo on the inside of the door will pop right out. Usa a flat blade.
ilikehamm
#4 Posted : 14 years ago
ilikehamm
:eek: Call a mechanic...
