purrgrace
#1 Posted : Wednesday, July 30, 2008 6:12:06 PM(UTC)
purrgrace
Dryer works okay. Heats up, drys cloths, but make a loud noise as the drum turns. Does this dryer have a roller you have to replace or is it the idler pulley? Open for suggestions, the noise is getting to me and I can't afford to call a repairman.
SublimeMasterJW
#2 Posted : Wednesday, July 30, 2008 6:33:48 PM(UTC)
SublimeMasterJW
This is a frigidaire/westinghouse/gibson type of dryer. The noise is from a worn out bearing. Get it fixed soon or the drum will eat its way into the heating element. a water valve double.jpg
SublimeMasterJW attached the following image(s):
