The brackets that retain product on the door shelves will not securely snap into existing interior door panel. The panel has been split and portions of the plastic chipped off. Superglue won't do it.
It appears as though a new interior door panel is necessary? (GE WR77X602, AP2073987)
Are any other parts necessary to replace when pulling off old interior panel?
Is this easily done?(replacing the door panel, removing magnetic gasket and other trim to get to old)
Thanks in advance for your feedback!
Easy to do, pull the gasket back and you will see all the screws and the brackets, once all the screws are removed the liner comes right off.
