3 Pages<123>
#11 Posted : Saturday, October 2, 2010 12:03:46 PM(UTC)
NJMom
#12 Posted : Wednesday, October 13, 2010 12:18:13 PM(UTC)
NJMom
Thank you guys. The repairmann came and after 2 weeks with your wiring diagram found the problem and replaced a part and now the oven works...however it is burning everything. He now says that the thermostat must have been blown out as well. The part # is 790332 or the newer # is W10125458. I cannot find either part.
Can anyone suggest where I might find it. I have been on the internet and calling around for hours!
Thanks in Advance
#13 Posted : Wednesday, October 13, 2010 4:56:27 PM(UTC)
Unfortunately this thermostat has been discontinued by the manufacturer.
There are a few web sites who does rebuild oven thermostats and it can be a solution for you. Just Google it.
NJMom
#14 Posted : Thursday, October 14, 2010 5:39:14 AM(UTC)
NJMom
Time to bite the bullet.... I am going out to look for a new oven!!!!!!
I extend my sincere thanks for all your help.
Cheryl
Joe / APP Team
#15 Posted : Thursday, October 14, 2010 9:06:23 AM(UTC)
Joe / APP Team
Originally Posted by: NJMom Go to Quoted Post
Well then, thank you ever so much!!!!!!
Sorry, but ...
W130 is a black unit.
W130-W is a White unit.
W130-C is a unit built for Canada .
That's were the Blue wire comes in ...
Joe / APP Team
#16 Posted : Thursday, October 14, 2010 9:23:28 AM(UTC)
Joe / APP Team
Everyone,
For future reference :
W130 Would be a Black J/A Walloven
W130-W Would be a White J/A Walloven.
W130-C Would be a Black J/A wall oven Built for Canada.
That explains the Blue wire in the harness.
NJMom
#17 Posted : Friday, October 22, 2010 4:54:42 AM(UTC)
NJMom
Hi again,
I need to replace the Jenn Air Electric 130W wall oven. CANNOT find the part to fix it anywhere (and I have tried!!).
My husband says he can remove the oven himself.
1- Does anyone have the install directions so he can indeed do it?
2- Also, anything we should be aware of before or after taking the oven out...as we need to cut the counter (I have a cooktop) to replace the Jenn Air wall oven and cooktop with a slide in range.
Thanks in advance,
Cheryl
Joe / APP Team
#18 Posted : Friday, October 22, 2010 5:24:03 AM(UTC)
Joe / APP Team
Hi again,
Thanks in advance,
Cheryl
NJ,
Since you're removing the wall oven,
There's not a lot to do other than removing power to the oven before you start, and being carefull, that is a pretty heavy unit.
When you open the oven door, you should find a couple of screws in the trim panel, holding the oven in the cabinet, remove those and slide the unit out, disconnect the 220 volt power supply, and you're done.
Good Luck
NJMom
#19 Posted : Friday, October 22, 2010 12:59:12 PM(UTC)
NJMom
Thanks for your answer and for solving the disagreement my husband and I were having. ..it will save us a service call.
I guess he was right, since I was telling my husband that I thought it was more that just screws, brawn and an electrical plug. He said that was all it was.
With gratitude...
Joe / APP Team
#20 Posted : Friday, October 22, 2010 1:12:33 PM(UTC)
Joe / APP Team
With gratitude...
You're very welcome !
Good Luck,
3 Pages<123>
