erin416
#1 Posted : Wednesday, October 13, 2010 12:57:14 PM(UTC)
erin416
what are the locations of the drum slides? do the red ones go on top as opposed to the white ones?
#2 Posted : Wednesday, October 13, 2010 4:57:25 PM(UTC)
What is the complete model number of the dryer?
erin416
#3 Posted : Thursday, October 14, 2010 2:47:45 PM(UTC)
erin416
model# DHDSR46EE1WW thanx
#4 Posted : Thursday, October 14, 2010 5:46:35 PM(UTC)
There are no more red glides. You have to use green glides instead. You have to order two of each glides. They should be installed on the front drum bearing (#313 on the diagram). Two green glides (slides) go on top of the front drum bearing and two white - on the sides of it.
- The white glide (slide) Part number: AP2041815
erin416
#5 Posted : Sunday, October 17, 2010 8:56:26 AM(UTC)
erin416
Thanx alot! Rec'd conflicting info from cust svc line, thanx for confirming for us!
#6 Posted : Sunday, October 17, 2010 1:10:24 PM(UTC)
Guest (4)
