Randron
#1 Posted : Wednesday, October 13, 2010 12:37:50 PM(UTC)
Randron
I solved one problem only to create another. I thought my oven door latch was broken. I popped off the contol assembly to access the latch. I discovered that the latch was unseated so I reseated it and everything is great. As soon as I reattached the control assembly I get an F2E1 error code(keypad keytail not connected). I'm hoping it was dislodged when I took off the assembly but where in the world is this connection?
magician59
#2 Posted : Wednesday, October 13, 2010 12:52:48 PM(UTC)
magician59
Here's a diagram that should help you see where the connection is.
Control panel replacement parts for WHIRLPOOL GBD277PDS3 | AppliancePartsPros.com
Randron
#3 Posted : Wednesday, October 13, 2010 1:15:29 PM(UTC)
Randron
Magician59...thanks for the reply. According to the tech sheet i should first check that the keypad connector is firmly connected. The diagram you provided doesn't show exactly where that connection is. When i press cancel I don't get a response. I can't even turn on the bottom or top oven now. My wife is pissed.
magician59
#4 Posted : Thursday, October 14, 2010 6:36:33 AM(UTC)
magician59
Once you have the console open, it should be fairly obvious where the connection is. If the ribbon is completely disconnected, the connector on the board is as long as the ribbon is wide; and just wide enough to accept it. There may be some kind of sliding "lock" that ensures a secure connection on the connector.
Randron
#5 Posted : Thursday, October 14, 2010 6:48:43 AM(UTC)
Randron
It looks like the ribbon has a crack or crease so I assume it got damaged when i popped off the control panel. So the question is do I just need to order the control panel assembly and/or do I also need the oven control board. Both are expensive so if i need both it almost makes more sense to buy a new oven. Thanks
magician59
#6 Posted : Thursday, October 14, 2010 6:59:36 AM(UTC)
magician59
You'll need to replace the touchpad assembly. The control board is probably undamaged
Whirlpool Oven Keypad connector (Oven Repair (including Ranges and Cooktops))
by kdunk 8/17/2009 7:00:32 AM(UTC)
