AppliancePartsPros.com
Appliance Repair Help
Washer Repair
GE belt replacement for WSM2700TCWWV (washer/dryer combo)
I think this one would work Part number: AP2137258
and it is a lot cheaper then the listed GE part! See if the APP parts folks can confirm the compatibility. If you order it from APP and it is not correct you can return it. See the returns policy.
We probably need to replace the dryer drum seals... I found the GE parts here on APP but they're $77 for the top seal and $51 for the lower seal. Are there equivalent Frigidaire parts that would be cheaper, and if so, which ones? Having trouble finding them.
Also, the link to the PDF you provided in Post #2 no longer works, the website now wants a user/pass and it's only available to Authorized Service Providers... any idea where I can find the service manual elsewhere?
Thanks!
Washer Repair
