Originally Posted by: ebasnight  will not heat up The first palce to start is the heater element and thermal fuse. Located on the back of the cabinet. Do you have a multimeter to test circuits and resistances ? You can vivually inspect the heater and wiring for broken, burnt, loose connections, if you have to. Good Luck, :cool: :cool: :cool:
