Hi ! I'm new here , hope all Bro welcome me to this forum . I need to learn about this and try to learn from all Brothers here about this problem . I have GE , model : GTS18DCPWRBB , serial : MM512604 It work about 1 or 2 hours , set 5 freezer and on 5 refrigerator . It stop work about 2 or 3 hours , ice melting on freezer, warm on refrigerator . I check compressor : not working . at the back close to the top I here sound tick ,tick ...fan in and out not working either . I try to unplug wait 30 minutes , the plugin , still not work , I keep plugin then about hours it kick on , fan work , compress working , cold but later around 2 or 3 hours it cut off . I check and know that ice freeze in side freezer alreaddy melting to water , that mean it may be not work at least 2 hours . So any Bro have any ideal what is the main problem about this . Help me out . Thanks in advance .
