maxcichon
#1 Posted : Saturday, October 9, 2010 8:52:09 AM(UTC)
maxcichon
Unit ran fine for 7 years and started cooling intermittently about 1 month ago.
The symptoms are:
No E fan
No C fan
No Compressor
Looking at the schematic, it seems the only things that will prevent all 3 from running is the Thermostat and Defrost Timer.
I checked the tstat with my Fluke and it seems fine. Open on satisfy and closes on demand.
I replaced the Defrost Timer from this website. Motor lead to terminal 1.
Plugged it back in. I can hear the Timer motor running (clock motor). Still no fans or compressor.
Does it have to run a cycle through the new timer to satisfy the circuit?
Help?
#2 Posted : Sunday, October 10, 2010 3:10:13 AM(UTC)
Measure across the fridg cold control while the fridg is running, if you get 115 volts, you need to replace it, AP3084361.
maxcichon
#3 Posted : Monday, October 11, 2010 8:29:52 AM(UTC)
maxcichon
Do you mean the thermostat? And is that the part number in your post? Thanks for the reply.
And as an update: it has been running for 2 days, but with a very large temperature swing (hysteresis). 38 deg to 49 deg. Is this a symptom of a bad thermostat?
