My Maytag front load washer will not spin or agitate. It will fill and drain. I don't see any codes on it. Any suggestions on what is wrong. We are 100 miles from any appliance repair.
Please click one of the Quick Reply icons in the posts above to activate Quick Reply.
Thanks for this info. I will check out a few things and let you know what I discover.
Just letting you know it was a motor control board. Unfortunatley to replace the motor control board you also have to replace the motor and no that does not fall under the warranty. Thanks for your help.
