Larchway
#1 Posted : Sunday, July 27, 2008 2:55:01 AM(UTC)
Larchway
I came home found the frig not cooling. These are the steps I took.
Removed back cover and saw condensor fan running.
Pulled connector off compressor and saw 120v there. (compressor warm)
Plugged back in and the thermal relay would trip every minute or so.
Put an amp meter clamp on one of the wires and saw it read 0 then jumped to 19amp then back to 0.
Is it safe to say the compressor has a locked rotor? The winding were around 6 omhs and 2.5 ohms.
Thanks for the help.
#2 Posted : Monday, July 28, 2008 3:28:10 AM(UTC)
Replace your compressor start device that's mounted on the side of the compressor (AP3083556)
Larchway
#3 Posted : Monday, July 28, 2008 12:42:42 PM(UTC)
Larchway
Ok. I was only able to get a Supco 3n1 relay device on a Sunday. Hooked it up per the directions to the run and common pins on the compressor and it still drew 19 amps then overloaded again. Does this mean the compressor is locked?
#4 Posted : Monday, July 28, 2008 3:25:42 PM(UTC)
Your start winding is burn out or compressor stuck from varnish buildup=new compressor time/ new refrigerator. I always suggest a new refrigerator, replacing compressor would be more than $400.
Larchway
#5 Posted : Tuesday, July 29, 2008 1:59:07 AM(UTC)
Larchway
Well, the wife will be happy now that she can get the latest style "French Door Fridge". WE WE.
Refrigerator Fans & Compressor not running after reassembly. (Refrigerator & Freezer Repair)
by EC Haney 10/15/2021 2:59:18 PM(UTC)
Monogram ZISB420DRI compressor not running (Refrigerator & Freezer Repair)
by gunns 7/13/2019 8:38:55 AM(UTC)
GE Refrigerator Compressor not running. Help! (Refrigerator & Freezer Repair)
by JohnHoward28 4/4/2018 12:12:37 PM(UTC)
Compressor not running & very hot after moving it to another room (Refrigerator & Freezer Repair)
by scsu96grad 9/27/2015 11:10:33 PM(UTC)
GE Profile Refrigerator PFCS1PJXB SS / Compressor not running (Refrigerator & Freezer Repair)
by nj1971 6/9/2015 6:58:43 PM(UTC)
Compressor Not Running (Refrigerator & Freezer Repair)
by jkon2 6/3/2015 7:16:22 AM(UTC)
wont stay cool/compressor not running? (Refrigerator & Freezer Repair)
by chadf 6/9/2014 5:44:37 PM(UTC)
by repairmon 6/8/2014 6:45:17 PM(UTC)
Power Outage Fridge Fans and Compressor not Running (Refrigerator & Freezer Repair)
by ulric999 3/30/2014 7:56:00 PM(UTC)
GE compressor not running (Refrigerator & Freezer Repair)
by kwolfe 3/16/2014 6:34:38 AM(UTC)
by jeff143143 11/29/2013 1:50:19 PM(UTC)
Fan and Compressor Not running (Refrigerator & Freezer Repair)
by BLACKATTACK 9/7/2013 7:31:11 AM(UTC)
by herman 6/18/2013 2:27:04 PM(UTC)
by Dean F 12/2/2012 3:04:41 PM(UTC)
Refrigerator - Compressor not running (Refrigerator & Freezer Repair)
by GAJOHNSON51 7/17/2012 3:38:28 PM(UTC)
