2 Pages12>
lon
#1 Posted : Thursday, October 7, 2010 4:14:04 AM(UTC)
lon
Used 2 days ago but yesterday it wouldn’t heat – tried varied temp settings. :) Smoothtop elements, broiler and 3 hr. self cleaning all work. We’re sr. citizens with no children and haven’t used oven frequently. Thanks in advance.
Joe / APP Team
#2 Posted : Thursday, October 7, 2010 8:38:09 AM(UTC)
Joe / APP Team
Lon,
I'm guessing you mean the bake selection doesn't heat ?
Did you look at the element itself , to see if there was any visible damage ?
Do you have a multimeter to check for voltage to the element from the control ?
Part number: AP4101290
There are several other possibilities, but I would start at the element to
determine wether you have a bad element or broken wire or bad control.
Good Luck,:) :) :)
lon
#3 Posted : Friday, October 8, 2010 7:00:58 AM(UTC)
lon
Thanks. I should have checked the element - will do. Yes I have a meter. You guys are both great and responsive - we couldn't do without you.
Joe / APP Team
#4 Posted : Friday, October 8, 2010 7:48:06 AM(UTC)
Joe / APP Team
Great,
Thanks for the compliments,and appreciation.
Let us know what you find,
Glad to be of help,
:D :D :D
lon
#5 Posted : Friday, October 8, 2010 9:05:45 AM(UTC)
lon
Joe, am unable to find a service manual for removing the bottom housing for accessing the element. Must I disassemble the entire cabinet?
lon
#6 Posted : Friday, October 8, 2010 9:24:27 AM(UTC)
lon
Joe, forget it. I just found the access screws in back.
Joe / APP Team
#7 Posted : Friday, October 8, 2010 10:31:45 AM(UTC)
Joe / APP Team
Lon,
OK,
Once you circuit test the element, if it checks OK(2500 to 3500 ohms).
Attach your meter leads to the two wires, that you took off the element and program a bake cycle and see if you get 240 volts across the wires, that will tell us wether we need to go up to the control, and check for damaged wires or terminals.
:cool: :cool: :cool:
lon
#8 Posted : Sunday, October 10, 2010 12:35:36 PM(UTC)
lon
Originally Posted by: Joe / APP Team Go to Quoted Post
Lon,
OK,
Joe, I ordered a new bake element from APP. The element had a 1" burn-thru! I'm 72 and never had a bake element failure. So much for Maytag quality, esp. since the oven hasn't been used often & is only 5 yrs old.
Thanks.
Joe / APP Team
#9 Posted : Monday, October 11, 2010 6:00:02 AM(UTC)
Joe / APP Team
Thanks.
Lon,
You're very welcome,
We're happy you've got it diagnosed and on the way to repairing and using it.
Good Luck,
:D :D :D
lon
#10 Posted : Thursday, October 14, 2010 8:21:41 AM(UTC)
lon
Lon,
Good Luck,
:D :D :D
Joe - (New element arrived) I removed old element slowly but wires came loose anyway falling behind cabinet. Can I "fish" them out or must cabinet be disassembled? Thanks.
Viking gas broiler and oven not working (Oven Repair (including Ranges and Cooktops))
by Guest 12/4/2023 2:39:31 PM(UTC)
Dacor oven, upper oven not working (Oven Repair (including Ranges and Cooktops))
by notyepcars 11/26/2022 8:40:21 AM(UTC)
oven not working, gives me a code F3 (Oven Repair (including Ranges and Cooktops))
by cj9113 10/16/2021 7:56:35 AM(UTC)
GE PROFILE PGB995DET1WW Top oven not working (Oven Repair (including Ranges and Cooktops))
by Guest 9/6/2021 9:36:45 AM(UTC)
Whirlpool microwave/oven not working (Oven Repair (including Ranges and Cooktops))
by naik71 9/3/2020 5:51:16 PM(UTC)
Thermador oven not working DP366CS/03 (Oven Repair (including Ranges and Cooktops))
by Chanmomu 6/30/2020 5:07:14 AM(UTC)
whirlpool WOD93EC0AS double oven bottom oven not working (Oven Repair (including Ranges and Cooktops))
by Chemsal 3/18/2020 3:28:11 AM(UTC)
KDRP467KSS08 / KDRP467KSS0 KitchenAid oven not working (Oven Repair (including Ranges and Cooktops))
by larrywick 10/18/2019 2:28:40 PM(UTC)
Oven On light stays lit - Oven not working properly (Oven Repair (including Ranges and Cooktops))
by Lometir 3/20/2019 7:54:34 AM(UTC)
ge oven not working (Oven Repair (including Ranges and Cooktops))
by mcp1212 9/25/2018 1:00:51 PM(UTC)
maytag range oven not working after self cleaning (Oven Repair (including Ranges and Cooktops))
by tpwd 3/27/2018 3:28:20 PM(UTC)
Whirlpool Accubake Oven Not Working (Oven Repair (including Ranges and Cooktops))
by buddha61 11/15/2017 5:18:32 PM(UTC)
Maytag oven not working (Oven Repair (including Ranges and Cooktops))
by dtmeyer 10/14/2017 12:48:25 PM(UTC)
Oven not working after self cleaning (Oven Repair (including Ranges and Cooktops))
by Nalk 1/20/2017 7:05:57 PM(UTC)
stove oven not working but burnerws do (Oven Repair (including Ranges and Cooktops))
by jnevill1 1/1/2017 7:20:12 AM(UTC)
2 Pages12>
